PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72
  1. picture request??
  2. wing mirrors
  3. ashley systems
  4. Badly behaved light wiper
  5. Fuel Pipe
  6. COSWORTH MAP SENSOR PIPE WANTED.......
  7. sorry if i sound thick
  8. thought is was time
  9. saff windscreen?
  10. head lining
  11. Group A rear beam ?
  12. 18" wheels on a Saff?
  13. Anyone know how to take a wing mirror apart?
  14. cap keeps coming off
  15. Anyone changed their fuel tank ?
  16. This gearbox fits into a 3Dr?
  17. poly bushes
  18. Rough guess on power....and some help Req. Please
  19. Got my BIG brakes, see pics.
  20. Was it you (Glasgow)
  21. 2wd Quaife diff
  22. dead cossie
  23. THINKING OF BUYING A RS500
  24. Different housing > what does it give you ?
  25. Headlight scoop / port..... pics ?
  26. how much can you pick up an early saff coss for?
  27. How realiable is a stage 1, 2wd sapp.
  28. Cooling tips 2wd Cosworth
  29. SPEAKERS
  30. COLOUR????
  31. Exhaust too low
  32. dump valves
  33. Glaenzer Spicer ref. for 2wd rear CV
  34. steering adapter wheel for a sierra 4x4
  35. front 2wd calipers in a 4x4
  36. breaking my sapphire
  37. Cossie rear diff
  38. just bought a sierra saphire 2000e
  39. question on 3bar
  40. Who does not run water to there turbo ?
  41. Shine the light, anyone know.....
  42. That injectores scoff at 42 lb/h???
  43. drivers side leccy window will open but not close.help pleas
  44. Anyone using Valvoline Racing Oil?
  45. Fuel spillage when fillng my Saff
  46. Speed camera detectors?
  47. engine rebuild. parts advice needed.
  48. is rwd cossie clutch the same as 4x4?
  49. my washer jets dont work
  50. Wheels for 3dr cossie!
  51. tickford badges and rs500 identification plate
  52. Head light wiper? (edit - repositioning?)
  53. saph wanted
  54. How to fit a 4x4 quickshift
  55. How much torque & power for a stage 1?
  56. HEATER PROBLEMS, HELP!
  57. brakes for saph on a £500 budget?
  58. repairing leather recaro's and cleaning them
  59. fuel pump question!!??
  60. High mileage. Should I be worried?
  61. 4x4 oil pump in 2wd
  62. Compomotive MO's in grey 16"????
  63. Dont flame me... please...
  64. What can be done with a 24v conversion?
  65. boost problem
  66. 93 brake caliper
  67. PLENUM SPACER....ANYBODY USED ONE?
  68. COSSY MAP SENSOR PIPE WANTED
  69. 0-100 times
  70. Ford stereo help please!
  71. Removing recirc DV
  72. What's your cleaning routine?
  73. What you got where amp was?
  74. 4X4 MAGENTA BONNET
  75. Whats the biggest discs and calipers under 17" wheels?
  76. How do they Cosworths are seen in the USA?
  77. I have my Cossie at last!!!
  78. saph trouble
  79. Quickshift for sapphy??
  80. What Flywheel
  81. Compression pressure in a 2WD Saff anyone?
  82. sapphire plugs
  83. MTD big tooth 4x4 gear kit question
  84. Compomotive 18" TH1's Anyone?
  85. fitting electric sunroof to a sapphire?
  86. Cosworth Knocking
  87. How many
  88. Carbon Fibre Bonnet
  89. CAT & MOT
  90. cossy fans
  91. 4x4 Gearboxs
  92. 3dr front bumper on a saph???
  93. Just a quick question... cheers
  94. How much............
  95. gearbox swaps T56 6 speed Vs 5 speed Getrag touring car box
  96. How much...
  97. Water injection Vs Charge cooler
  98. advice on buying a 2wd saf
  99. 90 spec sapphire cosworth colours?????
  100. Starting from standard spec
  101. Fitting a 909 Bottom Pulley?
  102. Will a RS 500 Splitter work on a RS front bumper
  103. Early Sierra Cosworth Wiring Diagram?
  104. Big power cossie, which turbo/injection setup??
  105. 3 door rims value
  106. How Do I Make a None power Sun Roof , Power
  107. Help T4 T35 T4 TURBO Sapphire Cosworth Help
  108. Sapph 4x4 fuel rail
  109. bmw cosworth - quick actuator question
  110. GT30 on standard compression
  111. few pics of my cossie. <updated 7th incar pc >
  112. power and torque
  113. what would cause
  114. blitz i.d sequential boost controler
  115. 4x4 performance figures
  116. How wider tyre can I fit with standard Sapphire rims?
  117. Newbie saying hello, just got a Cossie (PICS ADDED AT LAST!)
  118. cossie 4x4 lowering springs?
  119. Koni Set-Up Question
  120. BBS rims advice
  121. 4i turbo conversion??
  122. Brand new 3dr Cosworth & RS500 headlights
  123. Pic request: Cossie chrome rocker cover
  124. 'Fordsport' in Warrington
  125. gauges < in general >
  126. Was it you : White Sierra Cosworth write off
  127. 4 x 4 or 2 wd
  128. inside sierra fusebox..
  129. Rev Limiter
  130. Violent Jolting
  131. dodgy rev counter
  132. Rouse Sport sideskirts
  133. 4x4 exhaust manifolds
  134. General Maintenance&Servicing for a 1988 Sapphire -Help
  135. rs500/3 door side strips
  136. Zetec sierra
  137. Zoo Motorsports "WRC" rear suspension for sierra c
  138. WAT DOES A 3DR BREAK FOR
  139. Map 3 sensor Help
  140. Sierra Saphire Floorpans, are they all the same?
  141. CV Boots
  142. track rod ends
  143. binding brakes
  144. Which Tyres
  145. CHANGED DASH NOW NO SPARK OR FUEL...HELP
  146. Stage 1 Chip
  147. What clutch?
  148. sticky calipers?
  149. sapphire lights
  150. Bumpers are they the same?
  151. clutch cable
  152. Kit Car
  153. Cosworth 2wd help needed
  154. ** POWER ENGINEERING ROLLING ROAD SHOOTOUT ** 4th FEBRUARY
  155. snail trail
  156. Chip required for 3dr.................
  157. facelift issues
  158. fuel
  159. Smoking Cossie
  160. Ford power amps
  161. stage 3 kit help + turbo .
  162. smoke on idle
  163. BBS Centre lockers
  164. door strips .
  165. Ebony Black Saff on Imolas
  166. front bumper
  167. ATTENTION ALL.......
  168. diamond cut RS7 spokes
  169. External Wastegate???
  170. Supercharged Cos bits
  171. Help! Looking for Sierra complete Rear Axle!
  172. overboosting
  173. Idling problem???
  174. where is the water coming from?
  175. hand brake cable
  176. Sapphy vs Evo 4 GSR
  177. tyres for 17 inch wheels
  178. 2wd cosworth 88-92 4dr half cut with w/o engine - to buy
  179. anyone intested give us a shout
  180. Extractors on RS 500 Touring Car Fenders
  181. What chip for my t3 t4
  182. Sierra XR4X4i
  183. help me please - am i wierd?
  184. speedo not working
  185. RS 7 SPOKES
  186. By-bass the amal valve ?
  187. how much for a bottom end rebuild
  188. please help its a weird one
  189. any one owned my car before?or can give history?white rwd.
  190. How much boost on 7:2:1 comp
  191. big filter
  192. Seals for power steering
  193. how to fit a rocker cover
  194. saff underside pics please
  195. transit bottem end?
  196. conrod bolts
  197. diesal transit battery 4 a 2wd cos
  198. recommended mapper
  199. inlet temp and EGT gauges
  200. Cossie engine into 4x4 help.....
  201. dark carpet for saph
  202. Stupid Question but- What Oil Filter for my 2WD Sapphire
  203. front door weatherstrip fitting
  204. QUAD LIGHTS???
  205. 4x4 box and sump whats it worth?
  206. rolling road centres
  207. What brakes should I use
  208. anything special when fitting a bailey turbo damper?
  209. 1/4 mile time
  210. strutbrace
  211. Why no interest in bloody good 2Wd Sapp. RS?
  212. Saff Bodykit Clips ?
  213. HELP PLEASE!!!
  214. removing valves etc
  215. 7 spoke problems
  216. Is it at risk?
  217. higher rpm
  218. Brake back plates?
  219. Frame / Suspension mod. ??
  220. 2,9 XR4x4....
  221. 4x4 Sapphire Fans & Overheating
  222. 260 for catalythic car ?
  223. HYBRID or Standard
  224. sierra saph
  225. hoses
  226. how to find cosworths in italy/swiss?
  227. Actuator
  228. 3 bar map sensor questions
  229. Service book question 3dr cosworth
  230. Anyone know how many Sapphire Cosworths were made in
  231. amal question
  232. plate for your facelift saph
  233. What engine mounts please?
  234. rear brake discs
  235. Pair of 2wd front discs free to collector
  236. stiff steering
  237. STEERING PROBLEMS ( help )
  238. 2wd saff
  239. Exhaust housings....
  240. springs
  241. Using a bit too much oil Any idea's
  242. oil around cams
  243. diff ratio and main/big end torue settings
  244. Piston Slap??
  245. A good Strut Brace for a Sapphire
  246. classic insurance on a saph 4x4
  247. Black 2wd saff cozzie
  248. cliffnet wizard pro
  249. Cosworths in and around South Devon
  250. polybushed front end - opinions please
