amal question
Old 24-10-2005, 08:18 PM
filthyrichie
filthyrichie's Avatar
Default amal question
hi guys i refer to a diagram of the amal valve that was posted a few weeks ago which showed one connection being changed dependant on boost pressure.....i.e to earth if running at 16 psi can anybody shed any light on this for me please?
Old 24-10-2005, 08:19 PM
filthyrichie
Default amal valve
it describes a 3 way switch also????
Old 25-10-2005, 08:58 PM
JamesH
JamesH's Avatar
Think this is what you were after mate!
HTH .
Old 25-10-2005, 09:00 PM
JamesH
JamesH's Avatar
However I think, (not sure) you need all of those connected up, i.e what if you're running more than 16psi boost?
Unless I'm being thick
Maybe you or someone else could shed some light on this if you know?
Old 26-10-2005, 06:37 AM
filthyrichie
Default amal
yep that was the diagram its the 3 switch peice i dont understand.... do u change it depending upon boost being run????
Old 26-10-2005, 03:08 PM
JamesH
JamesH's Avatar
I will check mine for you tonight!
From memory though, it has a plastic connector thing, and one wire that goes into it, but I think the connector links to all of them!
Old 18-01-2006, 07:36 PM
snow*
snow*'s Avatar
*bump*
So now that I've removed my original factory Airbox on my 2WD Sapphire I just pull the "R" hose of the Amal Valve then and letting it sit there venting?
Cheers guys and sorry about the thread ressurection :P
Originally Posted by smidsy
HTH .
Old 18-01-2006, 07:40 PM
JamesH
JamesH's Avatar
If you've removed the std air box and have an air filter, just leave the one that goes to the air box (R) without any hose on at all!
Old 18-01-2006, 07:44 PM
snow*
snow*'s Avatar
Cheers smidsy
Yea mate, I've ditched the original airbox for a K&N Pod filter with polished trumpet.
Would there be any benefit in me welding a fitting on the trumpet of the Pod filter so as I could then re-run the "R" hose off the amal valve back to the new pod filter mate?.
Or is it just as happy sitting there bleeding to atmosphere?.
Cheers again
Old 18-01-2006, 07:48 PM
JamesH
JamesH's Avatar
TBH mate, I'd leave well alone once the trumpet & filter are happy and in place. Not worth fucking around with IMO. And top tuners certainly do not tend to disagree!
M7 COS
Wheels and Tyres
01-10-2015 04:46 PM
locum8
01-10-2015 01:50 PM
Iain Mac
30-09-2015 09:39 PM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: amal question
