PLENUM SPACER....ANYBODY USED ONE?
15-12-2005 | 09:11 PM
IVE SEEN A LOT OF PLENUM SPACERS FOR SALE.HAS ANYONE USED ONE AND DID YOU GET ANY GAINS FROM IT.CHEERS MARK
16-12-2005 | 04:09 PM
i think the flowseparation becomes worse with it
16-12-2005 | 04:48 PM
However the intake does get cooler hence denser
16-12-2005 | 05:49 PM
I bought one for my mate and he said that he felt a better response with the spacer fitted. Also the company(gns engineering) claims that you will gain more power! And they realy fit nicely!
16-12-2005 | 09:39 PM
im thinking of getting one,the one that follows the gasket line so it doesnt impede flow,best to get it mapped after fitting to make the most of the extra airflow
18-12-2005 | 07:37 PM
Lee cattermole TIB and MAD Rod tarry use them on here. I have seen them and really interested in them, especially if good gains are to be made.
What are the pros and cons on these, I would have thought it will help with flow as the plenum cover is so close to the trumpets?
21-12-2005 | 12:32 AM
for them to work propper the inlet "neck" needs porting,
on my saff its a 30mm spacer
11-01-2006 | 09:24 AM
*Bump*
Just to add to the confusion of the other thread :P
12-01-2006 | 09:44 AM
Quote:
i have never heard of this term before. can you please explain what it is and how and why it happens when a plenum spacer is fitted.
cheers
15-01-2006 | 10:08 PM
i´m so bad at english so i skip the explanation
but it´s all about that you move the inlet flow from the throttle away from the trumpets
timsrs
22
24-09-2015 08:14 PM
muffster
13
03-09-2015 09:40 PM
Russ Hill
31-08-2015 06:44 PM
Cosnada
27-08-2015 09:15 AM
20-08-2015 09:21 PM
