PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
  1. L8 ecu in 2wd cossie?
  2. cosworth 4x4 boost problem
  3. Going to look at 3 door at weekend what to look for ??
  4. 4wd saff transmission
  5. boost/driving problem
  6. focus rs brembo's
  7. Should I fit a turbo damper?
  8. where to buy rouse kit parts
  9. best looking saff and 3dr on here
  10. fuel pressure?
  11. Vibratechnics mounts?
  12. genuine ford pannels
  13. Does the Rs500 Suppose to have the plaque near gear stick
  14. Cosworth bumper brackets for sale
  15. comp brake adj TCA's
  16. Camshaft "tapping"
  17. advice on 8x18 on 3dr
  18. 3door rs500 alloy wheel centre caps and locks,help!!!
  19. strutbrace
  20. Been away and coming back - advice needed.
  21. Ford racing temp gauge fitting
  22. powerflex v flo flex
  23. spark plug question
  24. SEVERE WHEEL WOBBLE
  25. Whats it worth?
  26. Sapphire rear speakers - 5" or 5 1/4" ??
  27. HEADLIGHT WIPER BLADES
  28. how much do you like cossies?
  29. defi gauges in london or essex or in surroundin area
  30. BEWARE E BAY COSWORTH HISTORY FOLDER SOLD!!
  31. TURBO ???
  32. fit a skyline box to a saphire help!
  33. short shifters...whats the best out there **urgernt**
  34. AP racing or Comp Brake?
  35. temp gauge on 3/4
  36. Tuning companies.
  37. Buying a Saff...
  38. oil pumps
  39. Apexi AVC-R Help
  40. Saph 4x4 gearbox & diff oil??
  41. INFO ON SAPH'S
  42. OZ Mags 18 x 8.5 Centre Locks
  43. Did you know
  44. Port sizes
  45. 2wd / 4wd pistons
  46. Dump valve sound, or lack of !
  47. Replacing studs, discs and pads. Thanks and pics.
  48. What Camshaft's?
  49. YB Cosworth Thermal Inlet Gasket with double o-rings
  50. Saff offset
  51. where to get 3 door bits?
  52. Saph shell on rollover spit.
  53. Saff rear lights
  54. heater matrix on a 3dr?
  55. Removing gear knob...
  56. 3 door boot stickers?
  57. clutch ratchet
  58. 3 Door restoration help
  59. Will ap100 center console fit a regular Sierra ?
  60. turbo garrett 2wd & 4x4 sierra cosworth info?
  61. how to screw in back calipers
  62. tremec t56 6 speed box
  63. 4x4 front shafts
  64. Upgrade stages
  65. RADIANT RED SAFF !!!!
  66. Fuel lines and pump rewire
  67. Replacing wheel studs with longer ones
  68. which valve-sensor??
  69. hydraulic Handbrake conversion
  70. Gaz gold coilover
  71. tyre sizes for escort cosworth wheels
  72. saff interior
  73. who can repair ecu;s
  74. sapphire 4x4 poor starter
  75. What Oil Do I Use?
  76. what alarm,toad or clifford?
  77. idle speed valve??
  78. changing rear springs on saff
  79. dash gauges 3 door
  80. Clutch change on Sapphire Cosworth 4x4?
  81. Rouse parts
  82. Ford Racing boost gauge - buy or not buy?
  83. aftermarket heaunit wiring harness?
  84. Saff headlining
  85. my saf
  86. boost
  87. sapphire central locking problem
  88. Recommend me front brakes to fit inside 16" wheels
  89. Average MPG of a Cossie!
  90. oils pressure
  91. fues location for lights
  92. Clutch release beaing
  93. Miising Cossie Documentation
  94. HELP, WHITE SMOKE FROM THE COS
  95. silkolene oil
  96. oil pressure switch
  97. cosworth ford racing volt gauge wiring connections?
  98. L6 and L8 and P8
  99. breaking a cossie??????
  100. knock sensor
  101. model saph cossie?
  102. B&M QUICKSHIFT FOR A 4WD COSWORTH
  103. Best type of oil ?
  104. TEMP GAUGE SENDER WIRE & FUEL SMELL ISSUE
  105. cosworth Steering wheel snap off?
  106. Best places to buy these parts :
  107. newbee
  108. The cost of group A
  109. ***STARTED LOSING WATER 2WD SAPPH*** FOUND THE PROB
  110. rear big brake conversion
  111. New coil ..
  112. Is it possible?
  113. Wheres the diagnostic plug??
  114. External Wastegate Control?
  115. Help with Abs servo unit
  116. 4x4 saph thermostat probs!
  117. 360mm Brakes Under 17"?
  118. Strips for doors
  119. HELP!!!
  120. Sapphire a pillar gauge pod
  121. looking for metal side skirt clips for sapphire
  122. Saph parcel shelp removal
  123. Ral Colour for Lattice rims?
  124. saggy bumpers for sapphires
  125. Any pix of facelift recaros the black ones ??
  126. Brake problem
  127. B&M shifter for 4x4, stopped making them, where can i fi
  128. flywheel mods... what works ?
  129. Leather interior query
  130. heated recaros??
  131. performance time with the different stage upgrade
  132. Wheel Offsets for 2wd saph
  133. New Sierra prices & performance stats!
  134. master brake cylinder brake pump
  135. 18x8 offset40 rim on sapp
  136. 4x4 gearbox
  137. modified rear beam
  138. No pressure out of turbo into wastegate actuator?
  139. front 3 door bumper any one?
  140. plenum spacer.......
  141. wastegate flange, cosworth
  142. Merry Christmas from Canada
  143. Dizzy and dizzy caps
  144. VALUE OF A MINT 3DR COSSIE
  145. Monday (christmas eve) 8pm Men&Motors - Full Sierra show
  146. where from?
  147. Saph 4x4 ride height/suspension
  148. Tyre sizes
  149. BIG problems after rolling road
  150. SAPH 4X4 NOT WORKING ???
  151. front ARB relocation with compression strut
  152. boost problem on a 4x4 sapphire cosworth
  153. two tone
  154. Ford Saph stereo help!
  155. 2wd and 4wd dials/clocks....
  156. "wd handbrake cable
  157. Brake calliper paint?
  158. saph cos leather recaros ?
  159. new cossie owner and f****n lovin it!!
  160. Induction kit, fitted correctly?
  161. wing mirror
  162. Rear wheel bearings question, how solid should they be
  163. ap brakes
  164. Catalytic converter
  165. rev counter mod for coil pack help
  166. ideal tyre sizes on a 3dr?
  167. Rear wheel drive help, driving!!
  168. Powder coating help
  169. cosworth Bailey turbo damper
  170. Oil Filler Cap
  171. breather system
  172. fin code for clutch ratchet 2wd sierra sapphire
  173. carbon door cards for 3 doors - 1st pics of finished product
  174. 4x4 Values
  175. Building a new engine: need help to choose the right Turbo
  176. what is the difference between a standard coil and group a?
  177. what part does this relay control?
  178. fixed now
  179. what is the ideal offset for 8" wide rims
  180. Please help amal valve and boost on T34
  181. correct word of this!
  182. Electric windows
  183. Wanted partner in UK
  184. group a coil
  185. non starting cossie!!!!
  186. 343mm ap's
  187. How easy is it to fit a boost gauge?
  188. enlarge throotle body
  189. Max rim/tyre size for sapph
  190. Lost Keys
  191. Going to get a Cossie!
  192. 2WD sapp brakes!!!!!
  193. Sierra 2lt in a Spitfire
  194. cossie spark plugs mm?
  195. Saph parts
  196. ecu problems
  197. cossy hydraulic clutch wanted[info]
  198. How to fit electric sunroof on a 3door????
  199. Induction kit on Saph, is it ok?
  200. RS 500 & 3 door Cossie
  201. Mudflaps, worth anything?
  202. Rear light help!
  203. Uprights / stub axles 3 door vs 4wd vs Saph
  204. L8 ecu
  205. 3 Dr toolkit ...
  206. What hardware am I missing (3 Dr transmission) ...
  207. Car covers for sapphire
  208. insurance
  209. Had a day off sick to day..
  210. 3 DR Exhaust.
  211. too expensiv for me
  212. oil in number 4 piston
  213. Escos wheels on Saffs, what size tyres?
  214. my cosworth will not start.
  215. start problem
  216. Boot spoiler
  217. cometic multilayer head gasket max bhp?
  218. Newbie & some advice!
  219. What springs to 18 inch rims?
  220. battery light comes on
  221. Rs 4 spoke steering wheel boss
  222. Service parts
  223. phase sensor and idle valve
  224. Cossies running rich
  225. Rear Shock Absorber Upper Mounting Bolt... Sorted!
  226. Weird hold back at full throttle on my 2wd
  227. max BHP on light blues
  228. Maximum BHP on greys?
  229. compbrake???
  230. Oil grade?
  231. abs problem on a 2wd cosworth
  232. ambers............
  233. whats the wheel pcd for a sierra cosworth?
  234. steering wheel
  235. cossieboys valves........any good
  236. Rear beam rubbers removal, replacement
  237. 2.3l stroker kit
  238. Rear Sapphire Splash sheilds
  239. Bd16 cams
  240. 2wd or 4x4?
  241. Custom Exhaust needed
  242. Pre ignition, "pinking" or "pinging"
  243. GENERAL ROOM
  244. Which Intercooler
  245. off topic
  246. 4X4 SAPH COSSIE FRONT BUMPER MOUNTS
  247. intercooler
  248. Rear Brake Pressure Reducer
  249. 2wd calipers
  250. 2wd diffs.... population is decreasing...
