Saff headlining
take it yours is saggy?if so take it out and fix it with spraygle,i just did it to mine and its ok.if it needs cleaned then do that first as water dissolves the glue(it did on mine so i had to do it twice )if you need 1 because yours is damage then look at 1 of the posts in this section as somebody is breaking a 4x4.bit hard to post as they are very fragile!
Received 1,042 Likes
Mine was ok(not sagging)until i give it a clean. Then it started to sagg. I used some carpet glue from B&Q and its seemed to have worked. You just need to scrape off all the old orangey foam stuff off for the glue to stick.
