group a coil
group a coil
how do you fit a group a coil as the connections are different?
any suggestions?
thanks
[img]C:\Documents and Settings\ebay superstar\Desktop[/img]
any suggestions?
thanks
Cossiemodo
Yep as said a piece of piss to do. You'll need to buy a set of spades from HalFrauds or wherever. I kept the old plugs, which I figured I could crimp spades on to as well, should I go back to standard coil (if downgrading car prior to selling it for instance).
If you don't want to cut the wires ends off, use bullet terminals to join onto a little length of wire with spades on the other end to fit the coil, keeps your wires intact for bufty shows!!
The markings + and - are vital and can be found hidden between each pair of spade terminals sticking up, takes a little finding but look down between the terminals and you will soon see them, POLARITY IS VITAL.
07-10-2015 12:56 PM
