PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
  1. roller bearing T4
  2. 4.44 cwp match to what turbo
  3. Standard clutch
  4. rough idea on price..??
  5. Running rough when cold
  6. Sapphire cooling fan relay
  7. leak down?
  8. good tappets?
  9. 3dr boot rubber etc?
  10. 2wd driveshafts on a 4wd rear end ?
  11. How to Crackle Black My Rocker Cover
  12. Common places for 4x4 to leak gearbox/diff oil
  13. bilstein coilovers
  14. 3.38:1 diff in cossie
  15. Sierra Sapphire Cosworth Jacking point covers
  16. Ford 2007, 2040cd and amp wiring?
  17. Front Springs
  18. Another Sierra Cosworth Forum
  19. Fuel pressure setting...
  20. Light Greens
  21. A great find in a barn
  22. Best leather treatment for saff cos
  23. how to identify cams
  24. help wheel choice
  25. What chip is this
  26. on board computer died
  27. What is this
  28. 3dr ECU wiring cont.
  29. Inlet manifold earth wire?
  30. How much Oil does a T5 Gearbox whole?
  31. core plug came of while been dyno
  32. Cossie cuts out?
  33. Bearings, would you change them ? (HEAVY pictures)
  34. standard rear amber lenses saff?
  35. snapping osf driveshafts???
  36. GEARBOX?????
  37. rust near bonnet hinges?
  38. saph rubber door strips
  39. manual clutch adjustment
  40. Can i adjust the clutch cable on a 2WD saph?
  41. What colour is the window tint on a 90 black 4x4
  42. clutch cable and rear main oil seal?
  43. front bumper brackets
  44. 4wd to 2wd conversion
  45. how much?
  46. New Sierra Forum
  47. escos wheels on 2wd
  48. sounds like a f***ing bus!!!
  49. Amal valve connection & no boost?
  50. 3Dr Questions
  51. cossie 4x4, which fuel pump???
  52. Front disc sizes 2WD / 4X4
  53. Leather interior
  54. siemens injectors
  55. Change pinto for cosworth
  56. Propshaft
  57. Datastream enabled ECU
  58. can you still buy rear quater glass rubbers ?
  59. not fueling 4x4, please help...
  60. Rear wheel bearing
  61. Rock hard brake pedal
  62. standard TCA's still available from ford?
  63. 380-400 bhp
  64. Mates 4x4 saph-No spark???
  65. How much power
  66. starting problems
  67. Fuel lines on saph 2wd
  68. Saff 4x4 Engine Mounts
  69. Sierra bonnet vents
  70. how much is too much..??
  71. Coilovers questions????????
  72. gaz coilovers and 18" compo mo's
  73. gaz coilovers,how do you stop them...
  74. 2wd Sapphire Cosworth Brakes Pads and Discs
  75. ABS Sensors
  76. Transmission question..
  77. Amal valve
  78. ECT Sensor
  79. Sensors
  80. Saf dash top into 3 door ?????
  81. Fuel pressure reg
  82. Tappets....
  83. Missfire
  84. little cossie drift vid
  85. judder after rebuild..??
  86. 1000 posts n Fast Ford - THANKS PF folks
  87. Group a diff mount
  88. are all transmission tunnels the same?
  89. are all transmission tunnels the same?
  90. RS500 boot spoiler
  91. had a fiddle..??
  92. Running like a bag of shit...
  93. Saphire cosworth with stage three chip missing?
  94. what are all the differances between a 3door and a rs 500?
  95. information needed 3 door 4x4? i bought
  96. 3 door lower rear spoiler
  97. whats causing my smoke?
  98. 2.5 inch exhaust okay for stage 3?
  99. supercharger
  100. power drain on a 2wd sapph
  101. heavy clutch
  102. smoke stone blue saph spotted in plmouth, and a crystal blue 2wd in town centre
  103. RUST!!
  104. Clicking rear shaft
  105. cossie won't start....Have fuel and spark....confused!
  106. are 2wd saph tca s same as 4wd ??
  107. Whats needed to fit a 4x4 engine in a 2wd car?
  108. fitting uprated diff mount
  109. identifying a pipe
  110. plumbing in turbo cooler on 2wd saff
  111. Front hub nut torque on 4x4
  112. side skirt clips
  113. Air vent question
  114. side skirt rivets
  115. Facelift dash
  116. Idles way too high
  117. 2wd & 4x4 throttle bodys
  118. vibration through car when comin on boost??
  119. 2wd propshaft bearing spacers
  120. Grey Saph - G858 DVX (Spotted)
  121. FAO Jason who bought my LHD Cossie
  122. Wehey my new 3 door rides again..new wheels just on!!
  123. ECU Swap. L1 to L6
  124. What thread is the inlet manifold for dump valve/map sensor?
  125. How do I remove a saph passenger side door mirror??
  126. Cossie clutch cable
  127. 3dr wheel help
  128. chips the wrong way round?
  129. Gauges on late spec saff
  130. Wiring experts! Low voltage @ 2WD saph dash SORTED!!!
  131. brake reducer valve
  132. upping the boost..NEED ADVICE,running issues.
  133. No power to ECU on pin 20 on K Reg 4x4 saph
  134. Standard 2wd 4 pot brakes, what's the best disc?
  135. 3 DOOR Exhaust manifold
  136. sill protectors help!!!!
  137. Is this the right number for 2WD saph dash?
  138. Tyres
  139. 3 door accelerator cable,
  140. cossy heads
  141. Distributor, should it have a O-ring?
  142. Any1 know h755uvh
  143. new sapph fogs where from?
  144. Should i cry! Bad Rot!!
  145. compbrake
  146. genuine rs splitter for sierra i think??
  147. Headlight problem
  148. T34/2wd actuator bracket Part no
  149. Filter help??
  150. HT leads on dizzy cap .
  151. How do i find out my cars numberplate?
  152. Grp A YB headgasket....part number?
  153. Which relay is for the windows?
  154. Rear chassis leg on sapps
  155. me 1st cosworth
  156. Bag of poo Sapphire
  157. Std or uprated oil pump ?
  158. Torque of the Devil.
  159. low oil pressure when worm
  160. Heater Matrix
  161. different calipers on a saph
  162. spec-r breather question
  163. block or short engine???
  164. YB 205 bottom end rebuild
  165. Saff 4x4 coolant bubbling
  166. Any friendly people with metal work skills?
  167. Rough valuation
  168. Brake and fuel lines clips etc.
  169. aeroquip question
  170. Doe's it wind you up.
  171. best gearbox kit?
  172. bd10 inlet with gt3071
  173. FRont foglights
  174. Coilovers on a saff
  175. 3door crank pulley
  176. Another 4x4 front wheel wobble issue, is it a hub???
  177. oops
  178. Lattice, Sharktooth 3 door wheel offsets?
  179. 3 door colours?
  180. any cossie twitters?
  181. Valve Guides
  182. Saff cossie 4x4 front diff seal.
  183. any info on this 3 door?
  184. what do i need??
  185. FAO Adrenaline beam owners, help needed please..
  186. Phase sensor
  187. Question for an engine built with longer rods!
  188. ECU identification
  189. Cosworth spark probelm
  190. rear 2wd brakes to 4x4 rear vented
  191. What does the Alternator wire do???
  192. Fuel Vapour Valve!!
  193. wheels
  194. Is this a genuine rs500
  195. 3 door
  196. Cossies and MPG
  197. Saff cossie 4x4 sump gasket
  198. T5 gearbox!!!!!!!!!
  199. Petrol warning light 3dr
  200. Low fuel warning lamp
  201. 8x18 Super T's
  202. bailey breather fitting?????
  203. general probs to look for when buying
  204. sierra adjutable tcas.
  205. do all saff's.......
  206. thermostat
  207. FAO rollin rides
  208. Moving Phase Sensor to Cam Cover?
  209. steering wheel judder under braking... help
  210. Wiring diagram for 2wd saph dash????
  211. 2wd suspension problem
  212. 3 door front splitter
  213. toying with the idea of converting to RWD, what parts do i need?
  214. Hello all .. im new and need a lil help!
  215. thrust bearing
  216. Turbo for stage 3
  217. Tyres..
  218. wiring nightmare
  219. 2Wd saph, relays in fuse box, which is which???
  220. Power supply for 2WD saph dash????
  221. How is boot fuel cut off wired up????
  222. saph cage
  223. Sapphire relays in car, what are these for??? (PICS)
  224. Saph diff help!
  225. Whats the widest tire you will get on a saff?
  226. Cossie wiring diagram wanted, in English????
  227. saph roof rail gutter clips
  228. Cam cap torque setting
  229. saph 4x4 cossie thermostat housing
  230. Non -sunroof 3door cosworth?
  231. Good trader review - Enhanced Performance
  232. Whole dash not working in 2WD saph???
  233. Anyone got pics of a standard 2wd fusebox????
  234. Standard Wheels. Big Brakes. A pictorial.
  235. Aftermarket rev limiter
  236. Cosworth engine breather
  237. 2WD (PF01) throttle position sensor set up help needed.
  238. aftermarket brakes under 15's
  239. Squeeky rack
  240. 3 door cos speakers/sound system
  241. 4wd front brakes in rear
  242. failed test..
  243. £500 to spend on Brakes...
  244. 4x4 gear box oil seals/gaskets where from??
  245. leather ?
  246. t4 wastegate repair
  247. 3door cold idle problems
  248. 3door electric antenna
  249. 8x18 et 25 alloys
  250. ford battery
