identifying a pipe
identifying a pipe
i have a f reg saphire cosworth i am trying to identify a pipe i believe is leaking water its directly under the the injectors and fuel rail just above the oil filter its a black one and runs parrarel with the direction of the engine anyone know what the pipe leads to and from its difficult to see without ripping half the engine out
cheers
Dave
cheers
Dave
K managed to get to the pipes to see its the pipe that goes from modine to the rear of the head on the inlet side its split justabove the dubile clip
Anyone know where i can get one from
You can sometimes get away with just lopping the split bit out and stretching a bit, temporarily.
Don't know if std ones are about anymore, but sure begay will have some poly ones, maybe Matt Lewis 01543 484488.
If it is too tight you can cut it behind the block and insert some plumbers copper pipe with a couple of jubilees to extend it. That's how I found mine when I took it apart and I didn't even know about it! Obviously a new hose makes sense and I think Samco even do them in black now???
07-10-2015 12:56 PM
