do all saff's.......
If the swirl pot inside the tank isn't a very good one, under sustained hard acceleration they can do this when low enough, mine was same with old tank, over 1/4 no problem, also did it on extended high speed cornering.
I think that you should check the fuel tank as tabetha said because mine never do it even if I drive with the fuel warning light on no matter what cornering speed (400 bhp and 044 bosch pump). Maybe the pipe that goes to the swirl pot inside the tank has got a hole or something...
4x4 SAFF
Mine did the same the other day, but that was going around a corner quick and at the bottom of the red. The same sort of spec as yours aswell. Its never done anything like that before, but then again i havent run it to the red before.
You have a fuel supply issue of some sort, as in you aren't getting enough. Something i'd take very seriously! Its either you pump of the swirl pot system in the tank.
Pattern tanks can be terrible in this respect, the oe fuel tanks supplied on the cars had excellent swirl pots that were filled by the return line, before excess fuel over and above what the swirl pot held simply got pushed upwards and over the top into the main tank, these swirl pots were made by Mercedes!!, but worked ace, plastic in design, exceptionally unlikely to be a in tank prob with these as the pipes are all solid, right from tank outside to tank inside into the swirl pot.
If you hate working on your Cossie cos things go wrong, SIMPLY IGNORE the fuelling issue!
Then ENJOY fully rebuilding your engine cos a piston melted like I did.
Happily retired
yep!! mine did that a huge missfire when tank was near empty, sometimes would even fail to start until a gallon of fuel was put in & then all was fine. Never did get to the bottom of it, just kept tank 1/4 full.
I think it goes without saying that their was nothing wrong with the set up of my car, fully serviced every 1500 miles & fuelling check before every Topspeed run & no probs ever found.
Nope, it had over half a tank when it was there.
I worded myself a bit wrong above, i dont mean i hate working on it, it just worries me if i break stuff or cant put it back together!
Been out in it again now, with the same amount of juice and its been grand again?!
odd car.
odd car.
mrmann
20-08-2015 11:24 PM
