heavy clutch
sideways all the way!
i had my saff out for a show yesterday and there was a q to get out,and i nearly broke my leg with my clutch![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
its majorely heavy,its a alcon 6paddle,its a bit all or nothing in traffic aswell,i got in my golf and stalled it 3times
clutch is nice and light,after all that is there any way i can make my cossy clutch lighter without getting rid of the alcon clutch?
RWD IS KING
I had a alcon clutch in my mk1 with a standard cover, ive got the same clutch in my cossie ot sure which cover i have in cossie tho but is terrable, like you say its very on a off nightmare if your on a hill,i think the mk1 was so nice was because i had a hydro clutch conversion,makes a hell of a differance imo
so a hydralic conversion might be what it needs,mine same its a pig on the hills,either rev the tits off it or stall it,not sure what cover mines got either.
Done a few xr4i's hydraulic clutch, the difference is like Al says, night and day really, just a like a slightly heavy accelerator pedal in comparison when hydraulic.
BMW E30 slave cylinders can be used quite easy, with 0.75" master and remote reservoir.
Agreed Jon, often a new cable will make it feel a lot lighter ( obviously fdoesn't apply if you've recently had a new cable! ) and worth wrapping in Agriemach near heat sources
funny you boys are sayin clutch cable,it was routed under the sump(dont no why) and got moved away just before i parked it up last,ill have a check of that could well be that.
