clutch cable and rear main oil seal?
sideways all the way!
as above can anyone tell me best place to get them from?
the clutch is a alcon paddle clutch.
is it worth changing the oil seal while the box is out?
also my power steering feels heavy,plenty of fluid in it, or is it because i dont use the car that often? and my daily driver has got real light steering
I would give Matt Lewsi a ring first, 01543 484488, if not still get them at ford afaik.
For the rear seal I would try and get a Viton, massively tougher and better.
I have to get them from a seal supplier by number, the 3 set number on the seal itself.
They're good seals and are designed for high temp work, but around 2-3 times the cost of std ones.
This is inside diametre outside diametre width, unfortunately not all sizes are available, as mainly used on industrial machinary.
I don't know the seal number of this so can't even say if available.
Wilsfoci
15
30-03-2016 10:26 PM
muz
16-08-2015 12:57 PM
st220kyle
16
14-08-2015 06:13 AM
