fitting uprated diff mount
I think there will not be room for this bit with poly diff mount on, or do you mean a 909 mount and not a poly one, will fit with a uprated 909 mount, but not with MC2Racing poly mount.
VAST improvement with it fitted as well, best suspension mod money wise for the cossie.
it's that thing to stop the tank from bending if you have a rear ender and getting punctured by the diff isn't it?
not enough space to put it in if you forget to put it in with the standard diff, so not sure if it's going to fit with the poly one
it's got a little tab top and bottom and yes, it simply pulls out
well, i say simplybut it might be a bit difficult, so you may need to lever it out
when oyu put it back in, just lube it up a little and it will pop in, just make sure you put it in before you fit the diff mount as it won't go in afterwards
got it out with a lever, struggling to get the top bolt holding the mount onto the diff out, ARB's int he frigging way, need to lever the diff down a bit methinks, job for tomorrow.
Also, what are the plates on the bottom of the beam mounts for, the one that the main bolt goes through, then the 2 bolts hold that to the body? They captive nuts have come loose on mine, so i cant undo it, nightmare.
just unbolt the rear anti roll bar mate let it drop down out the way(only 2 13mm bolts!)Trying to picture what you mean with regards to the bolts??unless the 4x4 has a different bolt set up to a 2wd?mine just had the 4 bolts that hold the mount to the body then the 3bolts that hold the mount to the diff
well, they are in like a dropped down mount arn't they, and there's 2 access holes int he side of it, i think i could nut and bolt them afterwards without too much trouble, thats my plan anyway!
got same problem just now,but how easy will it be to remove in future if use nuts n bolts,im tempted to drop a bolt down hole and weld it in,trying to workout an easy way,will try something in wee bit,need car back together!
i am hoping it'll never need to come off again, if it does, it'll just be the same way i do it now, will let you know in a bit with any chance!
Just got he diff mount on after dropping the ARB.
Gadget
Ford Escort RS Cosworth
14-08-2015 08:19 AM
Gadget
13-08-2015 09:19 PM
xr4x4rs
06-08-2015 10:03 PM
