Inlet manifold earth wire?
On a 4x4 cossie there is the wiring loom which bolts to bottom of plenum cover and there is a seperate earth wire coming off the loom.
Where does this go??
I only ever had 1 earth wire point, was two wires in one connector fitted onto a bolt on the throttle bracket, never had any trouble, both my L6 looms were the same as that.
Wrong by me : I thought that the wire was coming from the front side of the inlet manifold but as above if it is from the rear then on the bolt at the lower corner of the manifold.
DixieTheKid
11
06-06-2020 11:20 AM
The Enigma
12-09-2015 10:12 PM
Si B
12-09-2015 06:49 AM
