4.44 cwp match to what turbo
Rally nut
You can go up to 120-125mph depending on your wheels (I'm gonna use 17" and probably 215/40 tyres), and rev limiter (mine will be 7500rpm). I think the best to use with 4.44 is a T34 with 0.63 as you don't go too low in the revs so
The max i would go is 4.1 really, but tbh i'd go for 3.9 as that is the best of both worlds IMO.
I always said my perfect Saph would be the Gunship conversion on a 3.9 diff.
Sorry, i just read my reply back and it didn't help answer your question at all! Lol.
As Matt said, T34.63 maybe, as you will never be low enough down in the revs for it to drop off boost.
Rally nut
I don't know about GT turbos mate, but I have a T34 0.63 because it has a maram shaft so can run antilag, don't know about GT turbos. If you don't need antilag I guess the GT route is "better", but more expensive too. Can't help, but surely if you're using 18" wheels with 4.44 your top speed should be enough for normal roads. Highway will be boring as hell, but you have to decide if you wanna have a cruiser or a racer !
on tight road. isn't a 4.44 cwp be more fun to drive? it should have very good acceleration and cornering speed.... i read that some racing rs500 used 4.44 ratio too...but there are using t4 right?
4.44 is still the most popular available ratio , you just need to sort the ratios in the box and wheel sizes to suit this .
what would be the ideal rim size to use on a 4.44 cwp ?
use whatever 5th gear ratio, diff ratio, tyre size, and rev limit you've got/want
Top Speed Calculation Example
Tyre Circumference (for 225/35/17) = pi x diameter
= 3.1415 x 589mm
= 1851.34mm
= 1.85134m
Now 1 mile = 1609.344m
Tyre revolutions per mile = 1609.344 / 1.85134
= 869.286
Engine revs per mile = tyre revs/mile x top gear ratio* x diff ratio
= 869.286 x 0.82 x 4.44
= 3164.897
* TKO gearbox
Now, engine revs per hour = 7800rpm x 60
= 468000
Thus top speed = engine revs per hour / engine revs per mile
= 468000 / 3164.897
= 147.87mph
With 225/40/18 sized tyres (with 2m circumference), top speed = 159mph
= 3.1415 x 589mm
= 1851.34mm
= 1.85134m
= 869.286
= 3164.897
* TKO gearbox
= 468000
= 468000 / 3164.897
= 147.87mph
Rally nut
Didn't know the RS500 BTCC cars used 4.44. Always thought they only used 3.9.
Were there a track short enough to put 4.44 diff Ryan ? Could you tell us a bit more about the diffs used ? Just for my knowledge.
