aftermarket brakes under 15's
ive recently fitted some focus brembos, disks, lines & ferodo pads to my 2wd saph as i wasnt at all happy with the standard setup.
i originaly had diamond cut standard wheels which i loved but have jumped up to 17's to take the new stoppers
is there anything out there that will fit the standard rim and work well ?
thanks paul
thanks paul
Hi Spec R132 calipers and brackets. Fit under Lattice alloys, using standard size Cosworth discs and are much bigger than standard Cossie calipers with a massive pad, also much lighter. If you give me a few days I'll take photos of the calipers and pads next to each other and show the fitting of the calipers.
Charlie
Charlie
Presumably they give better fade resistance using the bigger pads than standard Charlie?
Will be interested to see the comparison between pad sizes and calipers if you manage to get some pics up later
