Low fuel warning lamp
Is there a way to test the Red low fuel warning lamp on a Sapphire Cosworth?
I know it comes on when the ignition is turned on and the Amber screen wash flashes a few times but thats it.
I have ran it as low as I dare before it runs out but I'm wondering if it will ever come on.
Any ideas peeps
Any ideas peeps
4x4 SAFF
Mine came on for the first time the other day, it came on when i was at the bottom of the red, drove to the petrol station about 5 miles away and it didnt run out.. im sure i read in the manual it has 10 litres left in the tank i wouldnt really want to try it though.
My screen wash light comes on when i flick the ignition.. but doesnt falsh. Does the same in my dads car aswell, but thats an xr so could be different.
as said above if the warning lamp flashers there is a problem with the sensor.
my petrol warning lamp come on when the gauge is reading below the red and on a long run i have done over 40miles with the light on, but round town i don't leave it much longer then 20miles befor i fill up again
cheeRS nick
cheeRS nick
Do you mean the amber screen wash light bud? mines flashed since day one and after 5 flashes it goes out. When the washer light level gets low it does come on though.
I'll have to leave my petrol to go right down next time and see what happens....
yes mate the ones above the clock. had five sierras over the years mate and non have ever flashed unless there was a problem with the sensor or wiring
Yes as said if either bulb flashes when switched on it indicates a fault, think my light comes on near enough on red. If your comes on when ignition comes on and then extinguishes this indicates bulb and circuit good so maybe sender is not making contact.
Martin
Martin
The fuel warning light comes on at the top of red in my cossie, on my other normal sierra it dont come on until the very bottom of red and when it does the fuel computer says ive got 50miles left.
A flash on any of these lights is a sign of a dicky connection, on that circuit, I am sure I read somewhere it being 1.8 gallons when red comes on, but best not chance it!!
Dr. Ickxs
15-09-2015 10:15 PM
