rear 2wd brakes to 4x4 rear vented
K***LMT
hi anyone converted there 2wd rear solid discs to 4x4 vented ? just need to know if i need the carrier or the complete caliper off a 4x4 as want to fit vented on the rears insted of the solids any info allways greatfull
thanks...
thanks...
I've been racing on 2WD rear discs and calipers and the rear pads have been wearing away very quickly because of the heat. Now switched to 4WD set up at the back with vented discs and see less pad wear and presumably cooler rear brakes. I couldn't say that I've noticed much improvement in braking though.
Pics here if you're interested: http://racecarprep.blogspot.com/2009...and-discs.html
Charlie
Charlie
Charlie
Charlie
K***LMT
hi thanks for the advice, knew it was a better idea than running 2wd just wasnt sure of the fitting of them.. so if i got the 4x4 rear calipers and discs they just bolt onto the original holes the 2wd one are bolted to ?
thanks to all
thanks to all
09-10-2015 07:38 PM
track.focus'd
12-08-2015 05:53 PM
