fitting konis to a 3 door cossie
rear shocks look straigforward and fronts little bit trickier but how the hell do u fit the rear springs is this a big job???
You need to remove the 6 beam bolts,rear shock, and roll bar connection to arm, and if i remember rightly the arm should then go low enough to remove the spring. Might have to unbolt driveshaft, cant remember. Not as difficult as it sounds.
bounce, bounce, bounce
If you'e got small enough spring clamps you can get em round the spring to compress it with just the shock removed.
It works on a saff 4x4 so I would assume you can do it on a 3 door aswell
jessie_rs
11
03-06-2019 04:57 PM
COSWORLD
14-08-2015 07:40 AM
track.focus'd
12-08-2015 05:53 PM
