3dr cossie brking pad warning light
i have a 3dr cossie and the brake pad warning light flashes on start up. i thought it was being caused by a broken wire on one of the brake pads so i replaced it, but the problem still exists. does anyone know what else could be causing the fault.
p.s. i've just fitted new pads, but the problem was there before.
cheers
cheers
3dr try checking your brake fluid level if ok diconnect the level low ind plug an see
if it goes out usually a faulty sensor on the resovouir will bring the light on good luck
