central locking problem????
There switches around the locks were only fitted for around 18 months, the others are switched from the motor itself, but these do pack up internally, they are not very good at all to be honest.
I already have replaced one of mine, but used a 4 door locking kit from Maplin's @Ł25, so still got three spare.
As said though just check for anything amiss, could even be a dodgy connector, at the central locking relay, not in the door at all.
OCD Victim
Okay, the switch round the barrel is for the factory fit alarm (only fitted from Jan 1990 onwards and will have 3 wires, brown, brown/white and brown/yellow). It is NOTHING to do with the central locking. Yes, the wires go back to the central locking module, but they do not work the locking system itself, more "piggyback" the factory alarm into the system.
You say it works from the switch inside fine, does this mean that all the doors lock fine?
You also say that it does not work from the key on the outside, does this mean that the central locking does not work, or that the key does not lock ANY door?
If the central locking is all fine from inside but only locks the drivers door from the outside, then I would suspect the mechanical latch itself is @ fault.
If operating the barrel does not lock any doors, then either the barrel is worn too much, or the lock is broken internally.
If the keys locks only the one door, then I would look @ the latch or the connecting rod as it would sound as if the latch is worn excessively and not moving the motor rod far enough to activate the central locking.
What happens when you try this from the other side? Do you:
a/ get the same problem
b/ all doors lock fine
c/ the central locking system "cycles"
It could still be the CDL module itself, but most likely it is the motor or latch. Wiring issues normally cause random "cycling" of the locks. If a master motor should lose its earth connection, then it would become a slave unit. This would cause the system to always "cycle" as these motors cannot operate on a single master circuit as they always require the second master to act as a confirmation.
both doors have the same fault, i bought new switches from ford, the ones that click on the side of the latch not the barrel (1988 saph) ive tried clicking the switch with my finger but still nothing, the key locks the doors manually, but no central locking, central locking works ok from the inside
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
