High CO and erratic lambda with MSD closed loop - Now fixed and info within
Team HOTHOT!
Took the taxi for an MOT this morning and as expected, everything was perfect
Except for the emisions check
Spec is:
MSD Closed Loop
Siemens 55Lb injectors
Wasted Spark
ALS + LC
Fuel pump fully rewired along with every other live feed (14.1 volts nominal voltage)
At normal operating temperature, with either with the lambder sensor plugged in or unplugged the CO wouldn't fall below 4% and the Lambda reading on the machine was either high or low regardless of rpm.
Unplug the labda sensor and it remains the same.
Then the cooling fans kick in and lambda goes to a perfect 1 (give or take 0.01) and the CO drops to around 1%
As soon as the fans turn off the CO raises to 4% and lambda goes out of tolerance.
The first thing I did was to try and reset the CO pot by turning it 5 turns anticlockwise and then 2.5 turns clockwise - this made no difference with the radiator fans off but as soon as they came on and the alternator was under load I was able to gain some small adjustment, but nothing compared to what is expected.
I have a sneaky suspicion that it is either the fuel pressure is too high (no way of checking untill it goes to MSD for a setup and it is a posibility since fiting an 044 fuel pump during the rebuild), the coolant temp sensor is out of tolerance, the TPS is faulty or the lambda sensor is buggered (even though this is a brand new universal narrow band item)
Since Stu is on holiday, as is James, I thought about picking your brains on here to see if anyone has had similar issues.
Spec is:
MSD Closed Loop
Wasted Spark
ALS + LC
Team HOTHOT!
I wouldn't say it's a problem for me - it's just something I want some ideas throwing about to the cause - I've narrowed it down to one of 4 things above and was merely looking to see if anyone else had the same thoughts as me
Tabetha - don't be a dildo
*** Sierra RS Custard ***
Sounds like a CTS issue.
The lambda side of things is all working pefectly once active, so its definately not the lambda sensor IMHO, cant see it being the TPS as that value isnt changing, its just the closed loop isnt being activated in the first place as it requires a CTS reading of higher than a mapped amount to do so, and I reckon that the CTS is faulty.
Take it over to stu to connect up to read the sensors and I bet its a sensor fault.
Team HOTHOT!
I thought CTS initially Chipper, but with the new fuel pump I thought the pressure may well be high too
Looks like the RP-Labs kit is next on my shopping list too
I'll chuck another CTS in for the time being and re-check the emissions levels untill I get time to nip over to Stu's
Fuel pressure isnt effecting the lamda side of things or it wouldnt be going to lambda one once the closed loop is active.
Fuel pressure might effect you when flat out obviously, but shoudlnt effect you in closed loop, and demonstrably isnt doing so in your case in fact.
Team HOTHOT!
Silly question though, why would it drop into closed loop mode when the fans kickin or the engine is electrically loaded (headlights, heated screens etc etc) if the CTS is faulty?
Team HOTHOT!
Hmmm, I'll check and double check then, but I remade all the earthing straps for the engine/chassis using some rather chunky cable
I'll also recheck the ECU earth tomorrow, but I remade that too as it looked a bit scruffy
Team HOTHOT!
Righty, I have just been doing some checking of various sensors and the general state of the wiring loom and have the following results - Do any of them look suspicious, as to me they all seem within tollerance, with the exception of the MAP sensor which shows a slightly lower voltage than expected (possibly due to the reference figure I have being for a standard item whereas I have a 3-bar item)
All voltages and resistances are with the engine OFF but the ignition ON.
MAIN POWER CHECK: 13.06v between ecu pins 19 and 20.
REFERENCE CHECK: 5.3v between pins 11 and 30.
MAP SENSOR CHECK: 1.63v between pins 11 and 15.
THROTTLE CLOSED: 0.1v between pins 11 and 17.
THROTTLE FULLY OPEN: 5.13v between pins 11 and 17.
CRANK SENSOR: 700 Ohm between pins 3 and 4
PHASE SENSOR: 833 Ohm between pins 5 and 23
INJECTOR: 2.8 ohm between pins 18 to 20
INJECTOR: 2.9 ohm between from pins 35 to 20
INJECTOR: 2.8 ohm between from pins 33 to 20
INJECTOR: 2.8 ohm between from pins 32 to 20
COOLANT TEMP: 2800 ohm between pins 29 and 11 - engine still warm (engine last run 4 hours previous)
CHARGE TEMP: 2200 ohm between pins 31 and 11 for 800 (engine last run 4 hours previous)
The fans are a seperate loom from the ISCV though? The ISCV shares the same feed as your TPS and amal valve...
Check the resistance between the battery -ve and engine head too, see if your earths are working correctly
Team HOTHOT!
Paul - 2 brand new earths were put to the engine (one to the block and one to the head and then to the chassis and then direct from the same mounting point to the battery) so all earths are good. Also the fan loom is one of my own items and thus seperate from the car loom.
I think I cracked it earlier by setting up the TPS correctly as when I then unpluged the lambda sensor and adjusted the global mod screw on the ECU, the engine tone changed significantly when the screw was adjusted (adjusted being reset to a base point by 5 turns anticlockwise and 2.5 turns clockwise)
Cheers Chipper - that confirms another train of thought I had
Team HOTHOT!
Just a little update to close this thread.
After resetting the TPS closed voltage to 0.27v and fitting a brand new ACT sensor and ECT sensor and a genuine Ford (Cosworth spec) lambda sensor, I took the old shed back to my mates garage to check the emissions on his Snapon Emisions testing machine.
Results are after a little twiddle with the CO pot that Lambda is now at 1 and CO is now at 0.9% - this is MUCH better than the 4-8% CO previously noted
So to sum up - a set of sensors from MSD at Ł65 + delivery (ACT, ECT, Crank and Phase) is worth it's weight in gold - especially if you don't know the condition of the sensors on your engine at the moment!
Russ Payne
25-09-2015 08:29 PM
