Removing the whole abs unit.
Old 26-08-2009 | 05:10 PM
borderfox's Avatar
borderfox
Default Removing the whole abs unit.
Right folks i,m really only thinking aloud at the monent on this,But if i wanted to what mods have to be done.
Ie what size master cylinders are needed,How many are needed.
How would i balance between front and rears.
And fit a hyd handbrake but still keep cables for a test.
Any advice would be brill and photos would be even better again.
Thank you all.
Old 26-08-2009 | 07:17 PM
oldford's Avatar
oldford
If you want to disable the ABS all you need to do is disconnect the fluid level sensor.
Old 26-08-2009 | 07:51 PM
borderfox's Avatar
borderfox
Not really what i mean but thanks all the same.
Like a pedal box kinda set up.
Track car,ish.
Old 26-08-2009 | 10:07 PM
Char1ie's Avatar
Char1ie
Take out the ABS unit and the original servo and re-do your brake pipes. Reinforce the bulkhead with a plate and mount a bias pedal box and new twin master cylinders from Burton power (or similar). Much lighter and simpler but no power assisted braking.
Here's the bare engine bay with a pair if cylinders installed:
Charlie
Old 26-08-2009 | 10:13 PM
borderfox's Avatar
borderfox
Thank you. how hard is the brake pedal after that. and how good are the brakes
Old 26-08-2009 | 10:18 PM
andy130's Avatar
andy130
i see your from ireland mate!
Old 27-08-2009 | 02:45 PM
Char1ie's Avatar
Char1ie
Good braking if the pads, discs, etc are good. Lots of pedal effort as there is no power assist.
Charlie
tankybaby66
06-02-2016 03:24 PM
Steve Escos
01-10-2015 07:57 AM
Quick Reply: Removing the whole abs unit.
