4x4 burn engine oil
4x4 burn engine oil
can my cossy 4x4 burn motor oil from bad engine managment, my chip is for garett t3 and the car is with garett t34. Is it possible to burn motor oil from bad chip
No but it can create an issue known as bore wash if not mapped properly where the engine is over fueling and washing the lubrication from the bores, this won't be the case with your car as you will be under fueling if anything as your turbo is larger than the chip is mapped for and you are risking your engine.
Most likely top end wear, whats the millage and power its running?
Martin
Martin
big_Rad
15-09-2017 09:36 AM
mrmann
20-08-2015 11:24 PM
JoeyBoyden
18-08-2015 10:52 PM
