Fuses
Old 18-09-2009 | 05:27 PM
cossiematt's Avatar
cossiematt
Default Fuses
Hi,
Can anyone tell me which fuse in the fuse box is the one for the rad cooling fans?
Fans aren't working, checked the fans work with a direct feed, checked the switch by bridging across it and i beleave the relay is working fine!
So i think it's either the fuse or the wiring, hopefully just the fuse but i have no idea which one it is
Any help greatly appreciated!!
Old 18-09-2009 | 05:37 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Iirc its a red 30amp one that has probly melted into the fuse holder
Mine done the same but not too bad so I was able to wire a relay into the circuit and take the load away from that part of the fuseboard
Old 18-09-2009 | 05:43 PM
cossiematt's Avatar
cossiematt
All looks ok in the fuse box tbh, can you remember what number the fuse was in the box?
Old 18-09-2009 | 05:58 PM
martysmartie's Avatar
martysmartie
Common fault, they need rewiring, if the fuse does turn out to be melted or blown it will only be a matter before time before it or the relay or the melts again.
Basically the fan loom was sub standard to start with and the fans have a habit of staying on for much longer than they need to the standard fan switch actually has a 10 degree span and with the fans being a "Juicy" component this is why the fuses/relays melt.
The fuse is a green 30A one, can't remember number off hand but it's right at the front of the fuse box where the clip is to undo it as is the relay.
You can either DIY the fan loom with some heavy gauge wire a SPDT relay or you can buy then off ebay ready made. The fuel pump loom suffers from similar problem with old wiring and would also benefit from a re wire.
Martin
Old 18-09-2009 | 06:01 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
As said above sorry got colour wrong but you will see it is deformed and or discoloured
Old 18-09-2009 | 09:09 PM
cossiematt's Avatar
cossiematt
Thanks for that, I think I'm going to make a little loom up for the fan and do the fuel pump while I'm at it. Better to be safe than sorry I suppose,
Old 19-09-2009 | 01:20 PM
You only need a spst relay, only 30 minute job, but as said absolutely vital if you want your car to last.
IainRS1700T
25-09-2015 06:44 AM
Flatlinedan
18-09-2015 12:41 PM
Rammer46
18-09-2015 08:31 AM
TrevCos
Alloy wheels and ICE for sale
13-09-2015 02:12 PM
Sierrasideways
15
31-08-2015 10:10 AM
Quick Reply: Fuses
