high iddle on sierra cosworth 4x4
what is normal iddle on sierra cosworth
my iddle is 1100 - 1200 rpm cold, and after that on normal engine temperature goes to a 1500 - 1800 rpm on iddle
Normal idle speed for a 4x4 is 900-950rpm, ~1200 when cold.
Your Idle Speed Control valve may be sticky, or you may have an air leak at the inlet manifold - either a split gasket or split hose.
It would be worth giving the iscv a spray with carb cleaner then furniture polish containing silicone afterwards.
Things that can raise the idle speed include the CTS if engine thinks it's cold, so could check CO.
The engine relies on air, so try adjusting when hot and electrical loads turned off, the bypass screw on the throttle housing underside, if this doesn't have the desired effect, then I would look for air leaks.
and what is iscv
what is CO
and what is iscv
CTS= Coolant Temperature Sensor (Blue colour sensor on inlet side at back of cylinder head underneath plenum is tricky to remove, believe is same on 4x4 as well)
CO= Mixture at idle given as a % value
ISCV= Idle Speed Control Valve (On inlet side of engine on top of throttle body, has white top with wiring plug, remove this by depressing clip it is then held in by two screws either side then a ring lifts off, the valve can then be removed.
Tip first try removing the wiring plug on top of ISCV with engine running if idle speed drops it shows it is being told to open this much in which case probably the CTS)
Martin
Martin
i turn off air temp sensor and Idle Speed Control Valve , and there is no difference
cold start 1200rpm and i turn off gauges end when engine go work temp is on 1500rpm
after that i turn on air temp sensor and Idle Speed Control Valve and rpm is the same
But if theres is no iscv connected, than the ecu cant give any signal to the iscv (even if it would be a false signal) so the engine is running on it idle rpm, that can be adjusted with that srew under the throttlebody
edit: @above...thats what I tried to say ^^
If still same after then you have air leak somewhere.
Martin
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
155lee
Aug 14, 2015 11:21 AM
