AP help
Old 03-10-2014, 02:54 PM
Tinshaw
Tinshaw's Avatar
Default AP help
Hi Guys I'm after a set of AP 330 cp5200 brakes, for my saph cos 4x4 but I'm worried if I buy them they won't fit behind my wheels???
They are 17 inch Supperlegra's..... So
1. Anyone had them under those wheels??
2. Does anyone have a set on I could try my wheel over before I buy a set??
Any help would be grate & I don't mind traveling as long as its not the end of the world.....
Cheers Lee
Old 03-10-2014, 04:19 PM
Caddyshack
Caddyshack's Avatar
Cheers Lee
Go to reyland, I think they will measure up and tell you what will fit, give them a buzz. I think Martin said he could have just a wheel and tell you the max?
Old 05-10-2014, 01:04 PM
Cossy Mike
Cossy Mike's Avatar
As above, I'm sure he'll know straight off if they'll fit.
These are 5200 calipers with 330's running 18inch Comps and there is a ton of room
So looking at these I'd say yes
Old 05-10-2014, 01:23 PM
Paul_RS
Paul_RS's Avatar
You will possibly need 5mm spacers, I had 7" wide super tourismos and they needed spaced to clear my APs. It's not the diameter of the wheel that's the issue, it's the back of the spokes hitting the caliper face that you need to watch for.
Old 07-10-2014, 09:19 PM
matthewpickup
matthewpickup's Avatar
I have those aps your talking about on a 4x4 with comp mo6 17" et 36 , I run a 3mm spacer but that's to give me a little room from my coilovers
Old 07-10-2014, 11:58 PM
cossiestu
cossiestu's Avatar
Can't remember what model mine are, but it's not the back of the spokes, it's the clearance on the inside of the rim, a stick on balance weight won't even clear the caliper...
