cosworth fuel pump wiring
Take the original black/red wire off the pump and use this to switch a new relay mounted in the boot (relay pin 85). Run a new wire from the relay (pin 86) to earth. Run a new fused wire (fuse and wire rated at 30A) to the new relay pin 30. From pin 87 run a new 30A-rated wire to the pump, and a new wire from the pump to earth.
When complete, check that you've got over 12V at the pump.
Mulechild
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
