Relay
Relay
Anyone know what the yellow relay behind the dash behind the speedo is for ?
When a turn the ignition on its clicking buts stops once started
Its cool Tony it cured itself .
you still no got that rad it yet?
disconnected the plugs going to the fans and the one on the bottom right of the rad. undo the bolts that hold the fan in place and remove. take of the top and bottom hoses of the rad. Undo the 2 13mm bolts from underneath that hold the rad in place and its off.
AUSTRIA
when the relay starts clicking again, buy a new one...
When the coil-switches of relays get defect they use to to that - they sometimes recover but I guess it will start clicking again
It could also be a bad mass connection that causes the coil-switch not to switch correctly, though...
DixieTheKid
11
06-06-2020 11:20 AM
