engine firers
Testing the future
apparently, the most flammable material in the engine bay is not the petrol as you would expect, it's the brake fluid.
that is why you must always have a heat shield around the master cylinder on a turbo engine.
its possible for a diesel engine to pick up and start running on the oil. if this happens stay well clear. the engine will rev well above the limiter until a) it runs out of oil and seizes ot b) catches fire. unfortunately no way of shutting the engine off if this happens
hmmmm
hmmmm
my PAS pipe in my astramax van was the cuase of my bonnet fire! was modded to do away with the 4x4 disactivating on brakeing.
the guy i got the van from is well known so no names but he used a BRAIDED FUEL LINE instead of a high pressure PAS pipe!
and to top it off PTS fitted it!!!
some pics of the damage...
before i rescued the van after sitting 3years... PAS pipe replaced 9miles ago
http://homepage.ntlworld.com/tom.wal...ore%20burn.jpg
the morning after...
http://www.uploadit.org/files2/05110...-dizzy-end.jpg
http://www.uploadit.org/files2/051103-burnt-cam-end.jpg
perfect excuse to make the bay look like this!
http://homepage.ntlworld.com/tom.wal...ent%20bay1.JPG
although now ive sold it to make a mk5 escort beasty...
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
On cossys, alot of the time its the rubber fuel pipe between the fuel rail and the fuel pressure regulator, this gets old and can split, spraying fuel all over a hot turbo!! I know of at least 5 over the years that have gone up this way!!Best to replace the pipe with braided hose, this is much stronger.
This will suffercate the engine, and hey presto, it'll dye before it dye's.
i know what u mean mate. I have a 2 litre pinto at the mo and the soundedening on the fireall was set alite by the exhaust and the shorted the reverse light switch out.
Put out in 5 seconds and a week of re wiring to get the thing running again. The drivers side indys wouldnt work either so we reqired em. It is running again and on the road soon.
James
Ps Cops went mad when it happened. dont know why? Oh would that of been cos it was in a petrol station.
James
