Gasket choice !! Help !!!
Ive just had this same dilemma, im going for the cometic as I think the group a's just seem to be a little over hyped and a lot of cash for what they are, and if you weigh the £150 for the cometic against the £300+ for the wrc gasket and think that it does virtually the same job I know which wins in my mind!
You can get a cometic tripple which is 57"Thou the same as grp A
I would personally reconmend cometic over grpA but if you got wire rung block use grp A
Regards Doug
Regards Doug
duno if it is right or not but i was told if you have a wire rung block then you could just use a standard gasket as it creates suficient pressure.
could be a load of bollocks though
cozzycol,
The 200 block i have is wire rung block.
Does this mean no Cometic gasket ??
Will i only be left with a group A option??
I spose if you think about it logically a steel gasket wont compress propperly in to the groove of the ring wheras a carbon gasket will
Hope that helps
Doug
Mc5506
05-10-2015 09:57 PM
