Front prop shaft
the 'official' answer is no - the XR one is supposed to have a smaller diameter tube.
However, I got one from a breakers off a late (H-J) 2.0 XR4x4 which was identical to the cossie one, even down to the part number stamped on it.. So I guess you just need to have a look at it and see. They will 'fit' though, although I suppose the larger tube of the cossie one would make it stronger.
Re: Front prop shaft
Originally Posted by MJ Designs
Is the front prop shaft on a 2.9V6 XR4x4 same as ones on a 4x4 Saph cossie?
