what causes over fueling
i think my rs500 is over fueling what are the probable causes the injectors are standard i think the colour is yellow only one set are connected i am using 57 plugs i have recently put injector cleaner in the car also the car hunts quite bad on start up for about ten mins and then tends to settle down any advice would be appreciated it also has a stage 2 chip
cheers
barrie
cheers
barrie
When my MAP sensor went my 3 dr started bailing fuel at a daft rate.
It wouldn't tick over and was crap up till about 4 grand when there was enought air to go with the fuel.
Rich
Rich
I had a similar problem and it turned out to be the Idle Speed control valve not working ( big round shiny cylinder thing just after the throttle body on the 500)
take it out and soak the end in petrol overnight, (just the end not the whole thing) and then gently move the flap valve inside up and down lightly with a thin screwdriver to free it up.
or it could be the blue temp sender at the back of the head by the dipstick
