Block Swap HELP !!
12-01-2004, 09:14 PM
Block Swap HELP !!
I am in the middle of collectig parts to swp my tyred 205 block to a 200 item.
I understand i will be able to use the crank from my 2wd block
Is everything else transferable or do i need a 4x4 water pump etc
The 200 block i have is bare ( waiting for my pistons to arrive)
Would it make any difference if i use a 4x4 head ???
Any help would be great
Thanks
13-01-2004, 05:45 PM
dont need water pump or thermostat housing they,ll swop. as
long as u got complete 2wd engine and acc u'll be ok, think the
crank ok 2, 4x4 head is better
13-01-2004, 06:41 PM
Yes i have started with a complete 2WD engine.
Does this mean all the little bits and bobs will transfer straight over
Do i have to use 4x4 water pump & thermostat housing if using 4x4 head?
13-01-2004, 07:21 PM
Nah u don't, but supposedly the 4x4 stat housing and pump is more efficient but dont quote me on that.
13-01-2004, 11:18 PM
make sure the 200 block comes with its own crank main bearing caps,as these are matched to there own block by machining and there position is numbered
14-01-2004, 02:53 PM
yep what they all said!
swaped my 205 bits into a 200 block and all fits straight in mate!
14-01-2004, 08:26 PM
Block swap
Yes my block came with the end caps !!
So if i want 4x4 water pump and thermostat housing i wont need 4x4 radiator or anything like that !!
Thanks for all help !!
15-01-2004, 02:49 PM
think u ok with rad m8 but some hoses are different
15-01-2004, 07:51 PM
block swap
Should be interesting when ordering my samcos
15-01-2004, 09:25 PM
well if u use 2wd water pump and thermostat u ok, but 4x4 are different
hoses, and theres 1 between pump and housing which samco dont do
16-01-2004, 08:47 PM
Thanks mate i will keep this in mind
gcfcos
59
06-10-2015 05:04 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
AJC
01-10-2015 06:47 PM
20/20 vision
29-09-2015 11:27 AM
20/20 vision
28-09-2015 03:03 PM
