Overfuelling/running rough
First thing in the morning (as faras i can remember in the cold) my cossie coughs and splutters a helluva lot. there is a smell of petrol and the plugs are sooty.
I know sooty plugs=overfuelling, but could this be anything to do with cold start problems??
The car runs light green injectors and god knows whatelse.
How can this issue be resolved, cos its gettin on me nerves. Will i be better gettin it set up properly, or is there somethin else worth trying first?
yeah it seems ok after a coupla minutes. no noticable coughing and spluttering after about 5 mins.
Where is the ISCV and what does it lookie like? how do im sort that? in the vauxhalls all u needed was some spanners and WD40. same idea on a cos?
HI,
TRY COOLANT TEMP SENSOR, SENSOR FOR ECU ENGINE TEMP, NOT SENSOR FOR (TEMPERATURE GAUGE ON DASH,, ALSO IF YOU HAVE THE KIT CHECK CO% AND FUEL PRESSURE, ALSO THAT YOU HAVE A STRONG SPARK AT PLUG'S,
Dave,
Dave,
cleaned the ICV with carb cleaner (actually, i sprayed it with spray glue first by accident.....cans are really similar
) and it idles much better!! (still overfuelling tho, not as bad)
cheers for the help guys
TPM961
15-01-2018 10:50 AM
07-10-2015 12:56 PM
