rear beam bushes removal!....help
Old 08-03-2010 | 09:07 PM
taittsierra's Avatar
taittsierra
Default rear beam bushes removal!....help
any tell me how to remove the bushes in the rear beam??thanks>evan
Old 08-03-2010 | 10:03 PM
AndyPen's Avatar
AndyPen
Is the beam still on the car? If so you can drop each side independently and place a block of wood above the bush... then jack the beam up and out it will pop. Am sure there is a thread on here somewhere mate.
Old 08-03-2010 | 10:15 PM
pacwest's Avatar
pacwest
Puller of the Wrench
That how I'd do it. Stick a rag on the wood if you have some nice paint on the beam.
Do the reverse to pop the new one in as well.
Old 08-03-2010 | 10:39 PM
Char1ie's Avatar
Char1ie
One of mine was stuck so hard that no matter what I did I couldn't get it out like this. Horrible job. I had to make a puller from threaded bar and it took me about two hours to get the second one out!
Charlie
Old 08-03-2010 | 11:03 PM
taittsierra
the beam is out of the car i was looking for prvious post but coud find none saying how to take stnd bushes out wen beam is off car>any ideas how to take them out wen beam is already removed??thanks
Old 08-03-2010 | 11:04 PM
taittsierra
Charlie
how did u set the threaded bar up to pull it out??thanks
Old 08-03-2010 | 11:09 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i used a 15 ton press lol, well my dad did.
getting the poly ones back in was an effort!
Old 08-03-2010 | 11:37 PM
Char1ie's Avatar
Char1ie
Long story and too difficult to illustrate without technical drawings It was a nightmare. TBH if I were you I'd go to your local Kwik Fit and ask them to press them out with their big press, and press the new ones in. Slip em a fiver for a drink.
Charlie
Old 08-03-2010 | 11:41 PM
taittsierra
Charlie
yea mite do that been thinking bout biulding a press for edges no so dis mit just be the excuse cus have all the bushes to do in the car.thanks for all comments
Old 09-03-2010 | 06:10 AM
Papillon's Avatar
Papillon
cut the bushedges off with a knife then put it in a vise with a bit of pipe pushing and a support on the otherside that allows the bushing to extract free withuot hitting the vise. Simple job reallt.
same principle as this only with the big bushing and som imagination
09-10-2015 08:38 PM
atm
01-09-2015 05:56 PM
Bosch
23-08-2015 01:31 PM
155lee
14-08-2015 12:21 PM
Quick Reply: rear beam bushes removal!....help
