suspension change
suspension change
i was wondring if any one could answer me this qusetion
i have a 3 door cosworth that i am restoreing at the moment but i have a problen does the 2wd serria saff rear running gear eg trailing arms,diff carrier and the anti roll bar fit on the 3 door cosworth and can i use my oringal diff
thanks for the help
DAL
thanks for the help
DAL
As above just to add, the sapphy roll bar is a LOT better than the 3 door item, had that to start with on my 4i, changed to sapphy, what a difference, lot shorter and stiffer, the 3 door cossie one does nothing really, need to make a plate up and weld on to attach it though, and either re weld arms/brackets or use sapphy arms but well worth it.
SMILER258
28-09-2015 09:04 AM
