T34.55 on a stage 3 3dr Cossie . Is it worth fitting it?
23-02-2010, 02:46 PM
Hi all,
My 3dr has a stage 3 fitted so the obvious
-Bosch Greens
- -31 Actuator
-3Bar Map senser
-Airtec 60mm RS500 style intercooler
-4'' full Mongoose Exhaust
-Standard T3 Turbo (which is in good nik)
-Ahmed stage 3 chip
-K&N induction Filter
I recently got a T34.55 Turbo with 360 bearing.
Is it worth fitting this turbo on the above spec?
What will be the advantages and disadvantages?
Cossie Ray
23-02-2010, 03:13 PM
worth it if you want more power, t3 will do 300 at a push, youd need a new chip to suit the turbo change but youd be looking at around 335 with that at a wild guess. Alot laggier than nthe t3 though
23-02-2010, 03:16 PM
Yes you could fit it Ray, but as said, it,d need a new chip, with the .55 housing it shouldn,t really be that laggy tbh, yes it wont have the punch your T3 has but it,ll do 350+ on the right set-up injectors etc...
23-02-2010, 03:39 PM
im running a t34.55 on my stage 3 set up and was rolling roaded at 353bhp! so as mentioned above with the correct set up its deffo worth it
23-02-2010, 04:07 PM
Gaz, What injectors you running on your set up?
23-02-2010, 05:54 PM
My dark greens were at 80% duty at 300bhp, and they were perfect as had just been cleaned flow tested.
23-02-2010, 05:59 PM
Quote:
Originally Posted by
RSCossieGaz
Not a bad guess of mine a Gaz??
Tab,
80% is ok though, wouldn,t push them anymore...
23-02-2010, 07:47 PM
I was thinking of getting a .48 housing for the T34 Turbo so it will spool up quicker.
23-02-2010, 09:00 PM
Cossie_ray
running 803's on mine and there on there limit!
23-02-2010, 09:03 PM
Cossie_ray
T34.48 is a nice setup for a quick punchy road car imo Ray, loved that setup on my old 3dr with Greys and live map.....
24-02-2010, 08:02 AM
Pete 3dr
Tab,
I know, that's why I put a set of greys in, then was set up on them, 0.97% CO, 137ppm, despite 180,000+ miles on bottom end runs like a dream, noisy dream as a tappet just packed up, but can wait till the bottom end is done in a few months, if I get time.
24-02-2010, 08:04 AM
*** Sierra RS Custard ***
Well worth fitting on that spec, but you will need a new chip of course.
24-02-2010, 11:35 AM
Great milage that Tab, just shows how good the old YB can be...
WHEN looked after serviced etc..
24-02-2010, 11:56 AM
I got myself a .48 housing so I think in a couple of months time I will install it and get me self some new injectors.
Thanks guys once again for your help. Much appreciated
Over and out
24-02-2010, 12:32 PM
Id stick with the .55 housing personally
24-02-2010, 12:38 PM
Its just that I have read and have heard some good things about the 55lbs seimens, or greys with a T34.48 .
Ray
24-02-2010, 12:50 PM
siemens 55lbs will work great with a .55 housing too
24-02-2010, 01:05 PM
Ray,
As Chip says, 55lbs will work with either of the above very well, you,ll get a punchy car with the .48 where-as with the .55 you,d have more power and so on with the .63.
55 Housing is a nice place to be aswell...
24-02-2010, 02:54 PM
29-06-2010, 10:26 AM
Did you ever fit the Turbo Ray??
29-06-2010, 01:40 PM
If i ever crack
and decide to go for more power i think it would be t34.55 with seimans 55lbs.
29-06-2010, 02:29 PM
Ridgey
If i ever crack
Next week then Dave.........
29-06-2010, 04:34 PM
I wanted a 55 housing but I've decided to sell my saff instead.
29-06-2010, 04:38 PM
BIG difference there Andy.........
29-06-2010, 05:26 PM
Pete 3dr
Pete, I have not fitted it as yet.
Still on the stage 3 with the standard turbo. The car is running lovely, So I am just going to enjoy it for a while. Maybe in a couple of months time.
I am in the process of tidying up the engine bay with some black tanks and some new hoses. So that is keeping me busy at the moment.
I still like the idea of the T34.55 with Siemens 55s, So hopefully soon.
Ray
29-06-2010, 05:27 PM
Sounds good to me that Ray...........
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
JasonPD
21
20-08-2015 07:36 PM
gcfcos
118
18-08-2015 05:53 PM
stickyslick
14
10-08-2015 06:27 PM
CabrioTurbo
01-08-2015 11:04 AM
