dash display problem sapphire cosworth
i have a big problem on my sierra sapphire cossie i turn the key no dash abs light no ignison lights the car starts okay i also have no rev counter or temp gauge but my fuel gauge works i turn on the lights the dash lights up what can be the problem can ayone help me
i had some job getting the housing with a barrel and key then just a couple of weeks ago i took the car out for a run and kids were throwing snowballs at cars one hit my windscreen and cracked it under the passenger side wiper must have had a stone in it so new windscreen
i have a few electrical gremlins i am trying to sort out if you want to have a look your welcome m8 heres my moblie number 07531308602 thanks again john
Sounds like your having a crap time of it!!!!!!!
I'll send you a text with my number when i get a minute, but my phone is on it's last legs. By the way, got a call off a mate yesterday, there's a black XR4x4 in Persley scrappy, so if you need any small odd bits and pieces it's maybe worth a look.
I've got all the wiring diagrams for 2 & 4WD's so even if I can't sort it first time around i'll get there eventually.
As said check fuse 22 almost certain to be the problem if not the fuse itself (Which only would blow for a reason) then the connectors not making good contact with wire underneath or corroded. Doubt it's the PCB itself but the test for this would be if the Graphic Display works (Centre console) as this shares the same feed.
Martin
Martin
cossie fan (unluckerly)
Martin
Martin
Martin
Martin
the picture of a car in centre console telling if lights are out and fuse 22 is okay not blown
but i have noticed the battery light comes on after ticking over for 5 minutes i checked the battery witha multi meter and the altenator is charging as i get 16.4 volts
It's a power problem, but as I say it's not the fuse unless its blown for a reason normally it's the contacts corroded or the wire making good contact itself check continuity on the two terminals with ignition ON, also make sure you are getting +12V to one side. That voltage seems a bit to high for my liking you may have a regulation problem.
Are you revving the engine hard as this is what must be causing the charge process as you would not have any charge without battery light. What I guess has happened you revved it hard and then the battery light came on which would make sense as the otherwise normally live is acting as earth.
Martin
Martin
Power is supplied via the black and yellow wire that comes off and goes to fuse 22, it controls all of these things that don't work. As martie said in one of his previous posts, if it's not the actual fuse it may be the connector that the fuse plugs into has corroded under the fusebox. My white saph had exactly this problem and it took me AGES to find out where the issue was, fixed it in the end and then sold the car.
Like i said before John, I have the diagrams somewhere and can take a look at it sometime soon hopefully.
okay i got the the dash display out of the black xr 4x4 i tried it in my cossie it wont work aswell so i guess my display is okay so i must have a problem in the wiring to the dash display can someone tell me how many wires connect to the ignision switch as i just put on a barrel housing and barrel
want to bring this up again, having this problem with my dash display, rev usually wont work, temp hand always works and oil,battery,indicator,full beam and handbrake lights all work.
the rev hand will sometimes work if you play about with the connection or tap the screen, and the petrol hand will work if you pull the plug out at one side, what could be the problem here?
well i might try a new connector if i can get a good 1, its doing the exact same with the two dashes i have, i have the wiring diagram for it here which should help things, i wonder would a new earth help?
well ive traced the whole pcb and split the dash to see for broken connections inside but all seems ok, ill report back after i change the connector..
Oh ok, you never said you tried another dash. No not really, the green wire which connects to the coil is the earth, the gauge has a switched feed to it. So you would need to look at this connection, it's worth doing this first before changing the whole connector, bearing in mind everything else is ok.
Martin
Martin
