xr4i cossie engine
Maybe ?, it depends on year, my xr4i(86) even had the mounts there from new for the sapphy rear roll bar, but had the std long type roll bar, I looked into this mod also, and a cossie, or rather what I was told was a cossie gearbox support fitted straight on, but didn't bother in the end.
Still got to be easy to mod though ?
can the Danny Adrenline stage 2 beam fit right in?
Beam will defo interchange between them, just note the different roll bars used on rear, same shape but thicker 14mm on cossie, not sure on your size, but 4i here was 10mm, even the 14mm one was not good enough to be called useless even!!
I managed to get a LT77(rover) box in the tunnel ,and they are quite bulky boxes certainly much bigger than T5, I modded the mount using the one I had and the rover gearbox mount together took about an hour, so no biggee.
09-10-2015 07:38 PM
kosienutter
31
22-08-2015 09:55 AM
lockie
31-07-2015 10:03 PM
