Bubbling window rubbers
Looks like the strip inside the drivers window rubber has corroded causing bubbling through the rubber. There is no way I'm paying the £90 plus on eBay for a bit of replacement rubber!
Anyone either repaired it or found an alternative to being royally ripped off?
Have you looked at what has caused the bubbling ? You will need to fix it before you fit your new rubbers or the same thing will unfortunately happen again.
Have you looked at what has caused the bubbling ? You will need to fix it before you fit your new rubbers or the same thing will unfortunately happen again.[/QUOTE]
Rubber lists are reinforced inside with a steel profile? are they not,
it is for sure how the sunroof seal is made, rusting from the inside out.
may be that is why it bubbles,
* can be a little rust under there the list is fitted to
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
DavidK
27-09-2015 02:55 PM
