Breather Kit
Can anyone recommend me a breather system that doesnt require the drilling of the cam cover? im having a t35 and Siemans 55lbs blacks fitted so need standard system binning.
I use the airtech one breathing from both sides of the block but you will need a return into the sump and this must be below the oil level.
You mean this one?
http://www.autospecialists.co.uk/Pro...oduct-756.html
These are the fittings I used for the block,
http://www.ebay.co.uk/itm/Cosworth-R...item3a941df3d6
http://www.ebay.co.uk/itm/Cosworth-R...item3a941df15b
![](https://passionford.com/forum/images/smilies/roi.gif)
