central locking
central locking
hi there i have a g reg sappier cosse and my central locking has just stopped working , dose any one know where i can find the main fuse or relay and the locking modual, there is a alarm on the car and this is not working the locking eather. i have chacked the feeds to the motor but no 12v there.
many thanks
pagey
many thanks
pagey
The fuse for the central locking is a twenty amp one, however if it has blown you would know straight away as this fuse also protects the interior courtesy lights and the radio. When you open the fuse box, you will see the bank of relays at the back and two lines of fuses. The central locking fuse is on the top line of fuses about five fuses in from the left, you cant miss it, its yellow (obviously). I think it is numbered as fuse 10? on the diagram moulded on the underside of the fuse box cover
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
