View Poll Results: dump valve yes or no
Voters: 48. You may not vote on this poll
dump valves?
the problem is WHO determines if 1 is needed or not. Tuners tend to contredict each other and i doudt there is a rule that if your engine has this, this and this it dont need 1.
i haven't got a dump valve on my stage 3 saph cos i love the chatter and am only running 20psi. Although when i had the dump valve on i did notice a reduction in spool-up time between gears... the fresh cooler air must make a difference!!!... so i'm saying YES
Originally Posted by Cos500
If your 18 then yes if your all grown up id say no, less is more.
agree with cos500. i think everyone follws the same pattern. i had a DV on the frst when i first got it at 19, loved it! then realised the chatter you get with efi!!
theres no going back to vrooom ptsssch for me!
d.v. defo impair the performance, you can defo feel the car pull quicker after a gearchange when you take valve off, turbo takes longer to spin up when d.v. fitted (obviously), i prefer not to dump
