T34 & T35 Difference's??
Can anyone give me a heads up on the differences between a t34 & t35 turbo?
As I've been looking in to different people's spec's etc with a view to getting my next saff up to around 420bhp.
I have read up on here that the housings sizes pretty much dictates when the boost will usually kick in but i'm unsure on the differences between the two??
Any advice would be appreciated.
I'm a proven on 407bhp on .48... Wringing its neck at 36psi... If I rung a .63 I bet it would see 420... So saying one won't do it is not exactly true ... People don't play hard enough
Monte 087
Ok maybe I should have worded my first reply differently, either way and I'm sure most would agree a T34 is not the turbo to be looking at if you are wanting that sort of power.
As you mentioned Mat, that's T38 territory.
So a T35 turbo is basically modified T34?? Internals / housings etc.
Are the T38 turbo's interchangeable with a T34? Exhaust mounting & straight forward set up? Or is there other parts needed to carry this upgrade out?
or theres a tt t38 dont know much about this one tho
call cr turbos ask for vince he will convert a t34 for you its just a t34.63 with the housings machined to take the bigger turbine shaft and comp wheel to t38 spec, i had mine done not that long ago by him sold it now as gone for more power, good for a reliable 400bhp up to around 450 if wanted.
Fiesta ZS. FF feat nov'11
I asked the same question on here, about t34/35 differences.
People said they were the same turbo. They aint.
2wd t35 is .55 trubine housing larger high flow comp wheel, double waste gate arm 5 degree cut back high flow exhaust wheel
TT 360 bearing -34 actuator
Russ Payne
25-09-2015 08:29 PM
