HELP needed with cossie
got the engine back in the cossie but having a few problems
no live to fuel pump but the car runs but shit put a live to the fuel pump and it cuts out ?
when it is running its over fueling other thing is ive broke the map sensor does the map sensor have any thing to do with fueling or is it just manifold pressure
thanx in advance
thanx in advance
snapped little plastic nipple bit off so tryed to do a tempary fix by drilling it and went two far in better get one on order tomoz
Sounds like its badly overfueling, when you connect up the pump it's probably flooding the engine, that's why it cuts off, does it stink of fuel when it cuts out??
the pumps not priming at all but the car will run but badly and yes theres a strong smell of petrol
will try and get a map sensor tomorow and see if i can find the problem with the pump live carnt see the live been down to the map sensor tho
i dont get how it runs with the fuel pump not working
fitted a new genuine map sensor today and its sorted it i ad a idea it would be this as its the only thing ive broke but wanted to check with you guys before i payed Ł115 for a new one
just the live to the pump to sort out now, was fine before i removed the engine
Karl 3dr
102
14-10-2016 08:17 PM
kosienutter
31
22-08-2015 09:55 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
