Saph 4x4 ecu issue
Saph 4x4 ecu issue
Hi guys, when i bought my Kreg saph it had a spare ecu with it as it was going to be used to install wasted spark.
After i sold the saph i sold the ecu and the buyer returned it saying the adjusting screw was missing.
Is this repairable as obviously the L8 ecu's are still quite sought after?
Thanks in advance
Thanks in advance
Fascinating concoction. Its a L8 motherboard installed in a L6 ecu case with the Co Screw AND its potentiometer removed and unsoldered from the motherboard.
The chip in there looks like its been in and out at least 10 times too as the bloody ink has been rubbed off the label!
On the upside, the chips specs are as follows:
Basic Calibration Specification for 5099:
Additional Features Installed:
- Originally Sold: Aug 2008
- ECU Type: L8 ECU
- Babyboard Required: Yes
- Encryption Key required: Yes - Green
- Pectel or Weber: Weber.
- Engine Type: Ford YB 2.0
- Engine Compression: Standard
- Head Spec: Standard
- Camshaft Spec: Standard:
- Injectors: Bosch 803s
- Turbocharger: T3.48
- Map Sensor: 3 bar
- Intercooler: RS500 type
- Closed Loop active: Yes
- Air Injectors active: No.
- Serial Data active: Yes.
- Anti Lag active: No
- Launch Control active: No
- Flat Shift active: No
Thanks for that stu, are the co screw and potetiometer replaceable?
Also as i now have a 1990 2wd sierra is this any use to me as ive heard of l6-l8 ecu upgrades?
Thanks mate, what is the cost involved in getting the wires changed and the new tps.
Also does the chip from my l6 fit or will it need new chip too?
JK12
33
26-04-2021 12:09 PM
jdsjojo
30-08-2015 07:48 PM
CabrioTurbo
01-08-2015 11:04 AM
