sierra 2.0 efi dohc clutch
the clutch in my sierra at the minute is gone and i was going to buy an uprated one but dont see any available for my model and was wondering is a 2wd cosworth one the same ? cheers john
Resident Wrestling Legend
221mm vs a 241 mm on the cossie and 4wd version, you can stick thei wht eh normal one as it will habel the power not a problem
if you want to use the other cltcht then uyou wnned to find the sluwheel from the 2.3 scopeio and use the larger clutvch bit ot's more hassle thant it's woth
Not entirely sane
Pinto clutch is the same fit so you can use an AP Racing upgraded one. You'll need to change the clutch pedal quadrant as well as the Pinto is not low lift. if you don't change the quadrant then the clutch will not disengage with your foot buried into the carpet. I fitted one to my Turbo Technics DOHC, along with the black 55 mm Escort quadrant. It was so much better than the paddle clutch I had in before.
Adam Graham
06-09-2015 06:04 AM
