Changing loom in 3 door
I have started to strip my engine loom out in order to fit a new one, I have a couple of issues,
The bulkhead grommet also carries part of the main car loom and without cutting the grommet I can't see how to remove the engine loom, also is there enough room without removing the abs block to remove and feed a new loom in.
I can see this being a difficult job to do any advice appreciated
Mine is a 2wd saph so very similar to yrs I believe. When I got my shell it had a main loom but no engine loom, and I fitted it with the abs block in place. The big grommet has 2 or 3 apertures in it iirc, and I'm sure it was part of the engine loom. Pretty sure that I didn't have to take the main loom apart or back feed it either. I did fit it with no engine, dash or interior so that made access a lot easier.
Hope this helps in some way.
cheeRS
cheeRS
ekjim
17-08-2015 08:57 PM
