Checking a diff-choice of two...
Hi lads, wanted to get my diff painted so its ready for when I put the rear end back together but I'm unsure which to use...
The one that was in the car when I stripped it down, or a good used one I recently brought /
Worried the one in it had a bit of swarf on the plug when I changed the oil but worked fine, or the stick the 'new' one in which I have no idea about....
Is there any checks I can do while they're both out on the floor?
Cheers, pete
Cheers, pete
cossie fan (unluckerly)
Take the back cover plate off and inspect the teeth on the crown wheel and pinion and also the 4 side gears that's about all you can do really with out taking it apart to have a good look at the bearings! If you had a dti you could check the back lass if you was keen!
