water gurgling noise behind dash
there is a water splashing or gurgling noise behind the dash of my sierra and the car is loosing water are these two problems related and if so what is it thanks
gurgleing from heater
HI
Sounds like a head gasket to me
Get a sniff test done at a garage
This is a test which sucks air from your coolant expansion tank through a special liquid , If there is conbustion gasses present the fluid changes colour.
Good luck Tim
Good luck Tim
HI John
The noise is conbustion gasses leaking past the head gasket into the cooling system
making bubbles in the water
You only get the mayonaise in the oil when the water is leaking into the oil
Get the snif test done
Cheers Tim
Cheers Tim
Mark RS
12-10-2015 06:01 AM
